Maxscript dropdownlist and button
Hi everyone, I’m a newbie to maxscript, I have something to ask about dropdownlists.
for example
rollout test "test"
dropdownlist test "test" items:#("A","B") height:6
button btn_test "get selection"
on test selected i do
	print	test.items[i]
on btn_test pressed do
	print test.items[test.selection]
createdialog test
the question is, how does item “A” (actionMan.executeAction 0 “16” – File: New Scene, Clear All) perform if the “get selection” button is pressed?
and item “B” appears (actionMan.executeAction 0 “40010” – File: Import File) if “get selection” button is pressed?
I really appreciate any reply, thank you
The question is a bit unclear. Are you asking how to trigger the selected behavior?
for example:
  • select “A” & press “get selection” = new_scene()
  • select “B” & press “get selection” = import_file()
yeah right, that’s the question I wanted to ask, can you do it?
sorry my english is bad
generally anything you want a UI control to do should be defined as a separate function
and the control then calls the function . It’s been years since I used Max Script, but here is a basic script:
		first you define a function for each behavior
		the commands for new file and open file actions are probably descibed under "MAX Commands" in the documentation
		http://docs.autodesk.com/3DSMAX/15/ENU/MAXScript-Help/index.html?url=files/GUID-0B41CCC0-92AC-4005-B6D6-4ADACD82D39C.htm,topicNumber=d30e656790
	fn new_scene = (
		print "action a: new file"
		/* define the new scene behavior here*/
	fn open_scene = (
		print "action b: open file"
		/* define the open file behavior here*/
	rollout test "test"(
			print	test.items[i]
		/* use if - then clauses to trigger the deisred fucntion*/
			if test.items[test.selection] == "A" do open_scene()
			if test.items[test.selection] == "B" do new_scene()
	createdialog test
When I used Max Script , I tended to pack all my functions and UI for a tool into s single stuct, as described in this CG Talk thread Max Scritpt structs are very useful for grouping functions and data together and avoiding globals.
I got it, thank you very much for the explanation, you are the best!!!
This is a thread you should absolutely read on Max Script tool organization:
https://forums.cgsociety.org/t/bobos-fast-tool-development-video/1575705
