Max Splines as Bones ActorX Export Problem
Not sure if doing this is a good idea or not but I skinned some thin tentacles using splines as bones. It works fine in Max, but will not export to Unreal using ActorX. Any thoughts?
not familiar with actorx for max, but it probably doesn’t handle max’s flexibility of being able to treat any object as a skin influence. you might have to attach some point or dummy helpers to cv’s on the spline and use those as the influences that get exported. just use the spline as the max-side rig.
ActorX doesn’t recognize max specific deformations…
Everything needs to be a bone type object. In max/actorX you can also use polygonal objects as bones, and these will work on export too.
Splines, point helpers, FFD, physique, won’t. (Correct me if I am wrong here, they keep adding functionality, and i can’t always keep up with it all the time)
I would do what Jeremy said, you can also try attaching the bones/dummies/spheres as motion path objects and adjusting the path percentage to get them where you need them along the spline.
2006年11月6日起,长沙市凡提供迪士高音乐并可跳舞的娱乐场所,营业面积超过400平方米(含400平方米)的必须设置安检门、[b]手持式金属探测器[/b]等设备,对入场的客人进行安全检查。警方介绍,将来所有酒吧和迪厅的安检门将联网,以监控其使用情况。 记者在采访中发现,大部分酒吧老板对安装[b]安检门[/b]表示欢迎,认为能改善酒吧的治安状况,更好地吸引客人。但也有部分酒吧老板存在疑虑,担心安装了可能对客源有影响。大多数市民对此举表示支持,但有部分市民担心个人的隐私会不会被侵犯。 “有了[b]安检门[/b],这下进酒吧玩安心多了!”长沙市民刘小姐笑着说。爱好泡吧的她,曾有过每周去酒吧5次的记录。然而,复杂的环境加上酒精的催化,酒吧迪厅等地有时会成为部分不法分子打架斗殴的场所,也常常使她为之担心。 昨日,长沙市公安局治安支队组织全市酒吧的安保人员进行安全培训。从本月6日起,凡提供迪士高音乐并可跳舞的娱乐场所,必须设置[b]安检门[/b][b]手持式金属探测器[/b]等设备,对入场的客人进行安全检查。
Thanks for the input. I figured I’d have to do what both of you suggested. Dummies (and Dummies do export as bones) distributed along, and path constrained to, the spline works, but it exports the mesh in the state of the last frame of the animation, and the animation runs backwards from it. Weird.
It also kinks the geometry a lot more than Max (Note: this may be a smoothing issue, I only just got it working the way you suggested, and then had to go do other things so I didn’t study it too closely, and Max may be smoothing it better). What I plan to try next is to use a clone of the tentacle as a bone. If it works better, I can try to optimize it some.
how many bones are we talking about here? i believe unreal doesn’t handle more than 4 bones per vertex, so if you have like 10 bones influencing a single vertex, you are going to end up with unexpected results in-engine.
Jeremy, nothing like that. In my test tentacle I used 10 bones on a 348 tri mesh, evenly distributed along, and path constrained to, the spline so as to try to mimic the easy setup, and smooth deformation that the spline as bone rig achieves.
And, I realized my idea of cloning a low res version of the tentacle as a bone won’t work, since I’d have to break it up into individual “bone” segments and that is more work than the path constrained bones.
Eh, it was fun to try, and your help is greatly appreciated.
ww.mail.ru one of leaders among servers of free mail which also has set of other interesting services, for example love@майл.ру, news, a horoscope, a chat, a photo and others。
I am in love with human hair wigs because they last so much longer than synthetic wigs IMO. I used to spend about $20.00/month on synthetic lace wigs. That may not seem like a lot, but do the math over a year’s time with a lace wig: http://www.royalmewigs.com
