[MAX] Export Chunks to OBJ in Specific Order
I’m looking for a way to Export Selected out of Max to an OBJ, such that I can control the order in which my mesh chunks are written to the OBJ file. I’ve done tests to see if selection order or the alphanumeric name of the meshes have an effect, but they don’t seem to.
Exporting to multiple OBJ files and post-combining is not possilble?
[QUOTE=Theodox;20792]Exporting to multiple OBJ files and post-combining is not possilble?[/QUOTE]
I would think that this is the best way to do it.
You can batch the export of the files and then you can combine them back, all via script.
It has been a few years since I worked with OBJ, but you may be required to extract specific chunks of the file and inject that into your original.
This would be my workflow for DAE if I did as you describe.
