Making Rendermonkey .fx export SAS (Microsoft) compliant
I did a quick trial’n’error step by step recognition on this one for my own work in progress / learning purposes.
I thought some other tech artists might fancy seeing this shared around as well :cool:
When you export your stuff to fx format : it doesn’t run as it is in the DXviewer.
That’s because it needs some SAS bananas (the Mircosoft one “version 1.1.0” not the Nvidia one “version 0.8”).
So here is what I found :
// Add a global parameter with the script version :
int sas : SasGlobal
	bool SasUiVisible = false;
	int3 SasVersion= {1,1,0};
// Add the proper transformation matrices names
// and their data bindings to make DXviewer happy :
float4x4 matWorld : World
	string SasBindAddress= "Sas.Skeleton.MeshToJointToWorld[0]";
float4x4 matView : View
	string SasBindAddress= "Sas.Camera.WorldToView";
float4x4 matProjection : Projection
	string SasBindAddress= "Sas.Camera.Projection";
In your vertex shader you’re probably multiplying position with the “matViewProjection” matrix.
(which is reckonned as “predefined” Semantic by R-monkey but somehow isn’t talking “DXviewer’s language”).
//So you need to split this from :
Output.Position = mul( Input.Position, matViewProjection );
//into :
Output.Position = mul( Input.Position, mul(matWorld, mul(matView, matProjection)));
Basically using the matrices you’ve declared previously in a slightly more decomposed fashion.
You should now have the beast not yelling “Reverting to the default effect.” anymore.
If you only see a black ball your textures are missing.
// You need to switch variables from this :
texture my_rendermonkey_texture
  string ResourceName = "C:\\bla.dds";
// to something like this :
texture my_microsoft_texture
  string SASResourceAddress = "C:\\bla.dds";
Et voila!:D:
Please feel free to add more of your findings if I missed anything else required.
Btw : some shader syntax coloring would be nice when posting code blocks : they seem to have a way to do this cool thing on XNA forums.
You have trouble using sas 0.8 in XNA?
What parts?
I’ve ran many 0.8 shaders in XNA without problems, so I am curious what parts don’t work…
thanks!
Well that’s a good point : I didn’t know that XNA was just handling sas 0.8
In fact I just started to have a look at the latest release 3.0 yesterday.
I’ve done very little C# before and as I’m not a programer it would cost me a lot of time to learn more : however it seems to be quite simplified and open to “code newbies” (like me :p:) : Microsoft wants to attract as many students as possible to use their Visual Studio “Express” products so there’s a cool community and plenty of tuts for beginners to start your own game…
I just thought that things were more “DXSDK-centric” and when I did some experiments with FXcomposer/Rendermonkey I’ve always been disapointed by double clicking on the .fx file and not being able to just see it in the DXviewer : which would be quite handy if I want to show it to somebody without requiring him to have my whole project setup on his machine.
Actually : the best would be to export a .exe straight out of R-monkey or FXC : that would be lovely (they should add that feature just like Blender does)
I think I’ll start by pluging my .fx to a very simple basic XNA template app…
oh and XNA 3.0 has full latest FBX support as well : sounds exciting ! :D:
Sounds like some cool pipeline to look at for tech artists to bridge with Max/Maya.
But I’m not sure if XNA is actually widely used in production (maybe only for 360 quick small projects?) : hardcore programers just use C++ instead…
