Listing the entire graph of a node
In Maya, I wanted to listConnections on a node and have it return the entire graph of its connections except for ones that traverse a set node in an effort to find clusters of disconnected nodes.
I ended up having to write a script to do this. Has anyone else attempted this or have any suggestions to make this better?
def FindDisconnectedCluster( node, nType ):
    # List connections of node passed in
    conNodes= [node]
    conNodes += listConnections( conNodes, sh=True )
    #Counts used to determine if list of nodes has grown after listing connections
    count= 1
    newCount= len(conNodes)
    while newCount != count:
        for conNode in conNodes:
            # Prevent sets from being evaluated
            if nodeType( conNode, i=True ).count('objectSet'):
                conNodes.remove( conNode )
                continue
            #Verify all the nodes are of the current nType, just transforms or a set. If not, reset the conNodes list and bail.
            if not nodeType( conNode, i=True ).count( nType ) and not nodeType( conNode, i=True ).count('transformGeometry') and not nodeType( conNode, i=True ).count('objectSet'):
                return []
        count = newCount
        # Must get shapes to get the whole node graph
        # Make list a set  and then a list again to remove duplicate nodes
        conNodes = list(set(conNodes))
        newCount = len(conNodes)
    # Prevent sets from being returned
    return conNodes
