Is Load List Controllers exposed to maxscript?
When I load clips into the motion mixer through maxscript there seems to be no option to load list controllers (or max objects) so they end up being ignored. So far I’ve only found two ways to load .bip clips into the motion mixer.
MxTrack Class Method
appendClip <track:mxtrack > <fname:string> <ZeroFootHgt:boolean> <interval:timevalue>
The specified bip file will be loaded into the new clip, and the reservoir, using the ZeroFootHeight parameter.
For layer tracks, the start of the new clip will be appended interval time from the end of the last clip in the track.
The interval variable must be >= 0.
For transition tracks, the interval parameter is ignored. The start of the new clip will be at the inpoint of the last clip in the track, and it will be on the opposite row of the last clip. It will start later if it collides with another clip.
For both layer and transition tracks, if there are no clips in the track, the new clip will start at frame 0.
Returns false if the specified file could not be loaded. Otherwise, it returns true.
MxClip Class Method
 loadFile <clip:mxclip> <loadOption:name> <filename:string> <ZeroFootHeight:boolean>
This loads a .bip file into a clip. loadOption must be one of the following:
#singleClip (means load the file only into this clip),
#instances (means load the file into this clip as well as all instances of this clip),
#adaptations (means load the file into this clip and all instances and adaptations of this clip).
Returns true or false, indicating whether or not the file load was successful.
Both of these methods of loading clips are missing options to load objects and list controllers. Which is there if you load the clips manually and works fine, but it seems like this was either not added to maxscript, or was not documented? Anyone know why this is or if there is a work around?
When dealing with Biped, assume not.
