Information script,code
Hey all,
What kind of information do you add on the top of your script file?
What I do now is :
  • name of programmer
  • last time updated
  • goal of the script,code
What else do you add there?
Greetings,
Nysuatro
We used to post author, time, etc. at the top of our scripts, but not anymore. Perforce, like similar tools, has a standard for marking-up source files that get checked in, to fill that sort of info out, but we found that it was annoying when doing diffs/merges. Most of that info is available easily in Perforce/source control, where they all go anyway.
Instead, we just use a standard docstring header at the top (of our Python files). Looks like this:
Enter a description of the module here.
*Examples:*
 Enter usage examples here. (optional field)
*Todo:*
 * Enter thing to do. (optional field)
*Author:*
 * Joe Himdickel, joe.himdickel@volition-inc.com, 3/30/2011 7:49:32 AM
We use Wing IDE to insert those, which automatically fills-out the username, email and timestamp. They’re written in REST format so we can use them for documentation builds using Sphinx.
We have similar standard headers for classes and functions.
That is very interesting. Thanks for sharing
I also like to add the version of software. (eg: Maya 2011, or python 2.7, etc…)
We normally just throw some info at the top about what it’s for and what it does. If it has any ‘to-do’ items, or specifically unsupported behaviour that goes in too.
Generally though, versions, authors etc don’t go in as we use perforce for that kind of information. Many of our tools are altered/updated/written by multiple people so it’s hard to pin a single author as a tool progresses through production. That way knowledge is shared and if one person is not in for a period of time the rest of the TA’s can always offer support.
Same as above answers. All that traditional info should be in p4- who’s done what, changelist history, etc. If you need a ‘change log’ in the file, you need better changelist descriptions! If it were a python module I’d have a docstring like Adam says. I do feel todo lists are better kept in a backlog system (or inline comments) rather than at the top of a file, though.
Thanks for the information.
I once noticed people using xml for placing this kind of data on the top of the script files. Someone knows what the idea is behind this? I guess this is linked to a database system.
[QUOTE=Nysuatro;9935]I once noticed people using xml for placing this kind of data on the top of the script files. Someone knows what the idea is behind this? I guess this is linked to a database system.[/QUOTE]
There are many documentation-creating frameworks that use these XML tags as the basis of their automatically generated documentation.
We used to use RCS tags from P4 in everything but as mentioned they can make diffs awkward. So in general they were gutted – an exception being that some files are maintained where their revision and date strings contain values that are displayed in "about"dialog boxes and the like. But they are a very small minority of files, and those RCS tags are easily identified as being inside string constants.
