can any one help me figure out how to set render settings to a maya file by using maya standalone non GUI mode.
when using some commands like mel.eval(‘fillSelectedTabForTabLayout(“mentalRayTabLayout”)’), it is throwing an error. can any one guide me with correct procedure.
fillSelectedTabForTabLayout is a command that operates on the Render Settings UI. maya standalone doesn’t support UIs so that command won’t do anything. MR render settings are stored on the miDefaultOptions node. You just need to set the attributes on miDefaultOptions to whatever values you want.
For instance miDefaultOptions.minSamples controls Min Sample Level that you see in the Quality tab.
[QUOTE=capper;22970]fillSelectedTabForTabLayout is a command that operates on the Render Settings UI. maya standalone doesn’t support UIs so that command won’t do anything. MR render settings are stored on the miDefaultOptions node. You just need to set the attributes on miDefaultOptions to whatever values you want.
For instance miDefaultOptions.minSamples controls Min Sample Level that you see in the Quality tab.[/QUOTE]
Thank you for your reply.
when i am using mc.setAttr(“miDefaultOptions.filter”,3), It is displaying an error : - ‘No object matches name: miDefaultOptions.filter’
can you send me the code for standalone to recognize miDefaultOptions.
import maya.standalone
maya.standalone.initialize()
if not cmds.pluginInfo("Mayatomr", query=True, loaded=True):
cmds.loadPlugin("Mayatomr")
cmds.setAttr("miDefaultOptions.filter",3)
print cmds.getAttr("miDefaultOptions.filter")
Could you try it to rule out any environment issue ?[/QUOTE]
Hi nezus,
Everything working fine upto the line cmds.loadPlugin(“Mayatomr”). but when i run cmds.setAttr(“miDefaultOptions.filter”,3), it is saying “No object matches name: miDefaultOptions.filter”
if possible, can u please send me the attributes which are effected when i change the quality to “production” in the quality tab. so that, i will add them line by line in my standalone.
Thank you all for your replies.
your suggestions had helped me a lot.
lastly, can u please send me the attributes which are effected when i change the quality Preset to “production” in the quality tab. so that, i will add them line by line in my standalone.
