How to read a path which has ":" and spaces in it - Maya/Google Drive
Hello,
I have a question regarding how Maya reads a path. We - unfortunately - use Google Drive to host a project - which can’t be fixed/changed. But was wondering if anyone has suggestions in how to deal with the following issue where I have a scene located at:
/Volumes/GoogleDrive/Shared drives/Proj Art: Working/character/human/male.ma
Python sees the file but Maya doesn’t and says that the following file doesn’t exist:
/Volumes/GoogleDrive/Shared\ drives/Proj\ Art:male.ma
I am on a macOS.
Any help is highly appreciated. Thanks.
I do not have a mac to which I can help with the real issue. But you might be able to use a symbolic link so that maya/python etc have an easier time reading the path.
https://www.howtogeek.com/297721/how-to-create-and-use-symbolic-links-aka-symlinks-on-a-mac/
Are you trying to have Maya open the .ma directly from google drive? That sounds as worse than opening Maya files over a network.
Since python sees the file, I’d write a function to make a local copy from the url, renaming if needed, and open the local copy in Maya.
(also a function to ‘publish’ back to google drive when work is done.)
