How to check if window exists in Maya 2023?
Hello! I have had trouble getting my scripts to not give an error the first time they run in any maya version using python3. The second time it creates the window fine, I am not sure what should be different as it doesn’t look like a python 2 vs 3 thing to me. It works fine in python 2 Maya versions.
I’ll init a class with this:
class Window_UI:
    def __init__(self):
        if pm.window('myWindow', exists=True):
            pm.deleteUI('myWindow')
        self.window_id = 'myWindow'
The first time always gives the error:
Error: RuntimeError: file C:\Program Files\Autodesk\Maya2023\Python\lib\site-packages\pymel\internal\pmcmds.py line 217: Object ‘myWindow’ not found.
Then it works from that point on. What’s wrong with my code?
Thanks!
Just don’t use PyMel :slight_smile:
Especially in situations in which PyMel (compared to Python CMDS wrappers) does not provide any execution speed benefits, but instead executes commands more slowly and with additional overhead…
class Window_UI:
    def __init__(self):
        win_name = 'myWindow'
        if cmds.window(win_name, exists=True):
            cmds.deleteUI(win_name, window=True)
        self.window_id = win_name
Window_UI().window_id
Point taken! It works now using cmds, thanks very much!
