How do I export just the animation layer in Maya Python?
I’m trying to export an animation layer as a MayaBinary file in python.
I can’t find any clear examples on how to do it, has anyone tried it before?
My current work-a-round is to use this:
command = str('animLayersSaveExportClbc "' + export_filepath_mb + '.mb" "mayaBinary";')
mel.eval(command)
However this breaks all future standard exports. When I tried exporting a selection as an FBX it would not work correctly until I closed and reopened Maya. I’m looking for a less tedious solution if possible.
Stealing a suggestion from @VVVSLAVA :
If a specific mel command does not seem to have a maya.cmds equivalent,
you can always use whatIs("melCommand") to find the source file
whatIs("animLayersSaveExportClbc")
// Result: Mel procedure found in: C:/Program Files/Autodesk/Maya2022/scripts/startup/layerEditor.mel //
looking there we see that animLayersSaveExportClbc is just a wrapper for the file command
global proc animLayersSaveExportClbc(string $file, string $type)
	file -exportSelected -channels 0 -constructionHistory 0 -expressions 0 -constraints 0 -type $type $file;
so you can likely accomplish the same with maya.cmds.file()
YES! thanks a bunch I believe I have figured out the proper method now.
in addition to this file export I also need to select the proper objects that are not normally selected when simply clicking on the animLayer. This is how it was done.
targetLayer = "your_selected_animLayer"
export_filepath = "C:/Users/person/Desktop/testFolder/testing01"
cmds.select(clear=True)
cmds.animLayer(targetLayer, e=True, writeBlendnodeDestinations=True)
layerCurves = cmds.animLayer(targetLayer, q=True, animCurves=True)
layerBlendNodes = cmds.animLayer(targetLayer, q=True, blendNodes=True)
cmds.select(targetLayer, add=True, noExpand=True)
for c in layerCurves:
    cmds.select(c, add=True)
for blendNode in layerBlendNodes:
    cmds.select(blendNode, add=True)
cmds.file(export_filepath + '.mb', type="mayaBinary", exportSelected=True, channels=False, constructionHistory=False, expressions=False, constraints=False)
print("Success!!")
I still need to do some more testing but I got a good feeling about this :slight_smile:
