I’m not sure what you mean when you say “add a parallel List” so I made a few examples of things that might be and hopefully one of them will be what you’re looking for. Also, in MEL those are actually string arrays rather than lists so I’ll refer to them as arrays in the examples.
string $A[] = {"ANIM_root1", "ANIM_Pelvis", "ANIM_Spine01", "ANIM_Spine02"};
string $B[] = {"ANIM_root1_rig", "ANIM_Pelvis_rig", "ANIM_Spine01_rig", "ANIM_Spine02_rig"};
int $i;
// Example #1: Index into two (or more) matching arrays to make use of paired items.
print ("
Example #1:
for ($i=0; $i<size($A); $i++)
print( $A[$i] + " in A relates to " + $B[$i] + " in B.
// Example #2: Make a new array from alternating items of A and B (kind of like zip).
print ("
Example #2:
string $result[] = {};
$result[size($result)] = $A[$i];
$result[size($result)] = $B[$i];
print $result;
// Example #3: Append array B to the end of array A.
print ("
Example #3:
appendStringArray($A, $B, size($B));
print $A;
