Hierarchy reorder
hey guys im tryin to write a script that dose the following in max need some pointer on where to begin or if this type of script is out there
this so the frist obj is at the top of the hierarchy under the parent
select a parent
look for children an add to an array
detach them
sort by alphabetical order
then reattach starting by the first obj in the list
Not got max in front of me, but try this:
myarray = #()
theparent = $
select theparent.children
$.parent = undefined
myarray = getCurrentSelection()
myarray = sort myarray
for obj in myarray do obj.parent = theparent
Nodes can’t be sorted, but Eric I’m guessing you wanted to sort them by object name? If so, something like this should work, assuming the objects are named uniquely in your scene.
parent = $
if (parent.children.count > 0) then (
 child_names = #()
 for c in parent.children do (
  append child_names c.name
  c.parent = undefined
 sort child_names
 for c_name in child_names do (
  c = getNodeByName c_name
  c.parent = parent
If they’re not named uniquely you’ll have to go to more trouble. Like keep another array mapping node handles to names or something.
thanks guys ill give it a go on this an let you know thanks
it works but the order in the schematic view is still the same
ie
top
box03
box02
box01
box04
the scripts prints out the right order but in the schematic view is still like the top we want the order to reflect in the schematic view
