Help with a texture splatting network (screwed up texel density)
This might seem like a minor issue, considering the quality of most forum posts here (which looks like rocket science). I posted this at CGtalk at first but no one there seems to have a clue -_-
http://img827.imageshack.us/img827/3368/crapd.jpg
As you can see, I have connected the ARGB output of the splatmap to the transparency input of each material - and I’ve then connected the color outputs of these materials to the different color inputs of the layered shader.
But it’s somewhat broken as you can see here:
http://img23.imageshack.us/img23/8048/crap2l.jpg
The texel density is seriously fucked up - and changing the UV 2D projections on each of the materials doesn’t matter. So I must have made this all wrong.
EDIT: And the problem is not with the layered shader’s file map size - changing it doesn’t affect the TD of any of the 4 material sections.
EDIT 2: Also not working
Node network: ImageShack - Best place for all of your image hosting and image sharing needs
Viewport: ImageShack - Best place for all of your image hosting and image sharing needs
Here I used the outcolor (R, G and B) and the outtransparency of the splatmap and connected them to the input transparency on each splatmap channel/input. Same issue with the TD though… Also the 4 chan (alpha) does not appear as a color channel on the layered shader but as an alpha -_-
I think it’s just the viewport bake texture size. Try changing the “Baked viewport textures” setting in “Window > Settings Preferences > Preferences > Display” to a higher quality.
Maya uses baked viewport textures when you have any sort of complex texture layering (e.g. a layered shader) in the shader network in order to keep viewport performance good.
[QUOTE=Warheart;19224]I think it’s just the viewport bake texture size. Try changing the “Baked viewport textures” setting in “Window > Settings Preferences > Preferences > Display” to a higher quality.
Maya uses baked viewport textures when you have any sort of complex texture layering (e.g. a layered shader) in the shader network in order to keep viewport performance good.[/QUOTE]
Yea, that was one part of the problem.
The other two parts were: High Quality Shading in the viewport - I couldn’t get this working in the default view
Third part was that the Layered shader has to be connected to a new material: So I made a new lambert and connected the outColor of the layered shader to the input (color) of the new lambert material.
ImageShack - Best place for all of your image hosting and image sharing needs - Node network
ImageShack - Best place for all of your image hosting and image sharing needs - Terrain w working splatmap
