Hi guys, I have a little problem with a script that im trying to write for a maya UI, i just recently got into try python QT and pyside to create my maya UI.
I am fairly new to classes as well, which is probably what is getting me a little confused.
But im willing to try understand and achieve this , so if you see something that is completely off don’t hesitate to give me a hint(or more of a kick …) into the right direction :P.
The issue im facing is on how to make a list ( I am using the QListWidget which hopefully is the right choice… ) to work, and be able to do these 3 basic functionalities :
1- As i lunch the UI a def will be listing some stuff that i have in the scene and these will be listed in my QlistWidget (at the moment i can put some stuff inside the widget but it displays with no name…nor im able to do much with it…
2- as i press a “refresh” button , the list of objects in the widget, will be refreshed, which probably means, i will have to delete everything that i have inside the list, then call the Def that will add everything back in again.
3- if i double click on any of the items i want that another Def is called (possibly a select -r item inside maya)
4- if i do multiple selection of something in the list , by pressing a button some other def will act upon highlighted items
I think is all of the basic functionality for a “list” gui , i would like to understand better how these type of UI would work .
so far here is my code : (please excuse my commenting…)
from PySide import QtCore
from PySide import QtGui
from shiboken import wrapInstance
def maya_main_window():
main_window_ptr = omui.MQtUtil.mainWindow()
return wrapInstance(long(main_window_ptr), QtGui.QWidget)
class ssacUI(QtGui.QDialog):
items = ["ssitemss"] #static element fuck works but ??.i dont want it!??
def __init__(self, parent= maya_main_window()):
super(ssacUI, self).__init__(parent)
#since im extending the QDialog Class from qt, i will need to be passing
#all of the QDialog methods
#title
self.setWindowTitle("primitives")
#make it a tool window, so it stays on top of maya
self.setWindowFlags(QtCore.Qt.Tool)#using tool insted of window
#set an attr that will tellQT to delete the window once is closed
self.setAttribute(QtCore.Qt.WA_DeleteOnClose)
#####need to call the layoutMethod that i just created from the init since is a class to be able to visualize the buttons
self.create_layout()
self.create_connections()
self.buttonlist = []
#### creation of UI Layout METHOD
def create_layout(self):
# try adding a QColumnView ?..
self.listWidget = QtGui.QListWidget(self)
#add button
self.cube_btn = QtGui.QPushButton("Cube")
#add next buttons then have to add it into the layout few lines down
self.sphere_btn = QtGui.QPushButton("Sphere")
self.cone_btn = QtGui.QPushButton("Cone")
self.cylinder_btn = QtGui.QPushButton("Cylinder")
#--create the layout vbox#$#$#$
main_layout= QtGui.QVBoxLayout()
################ to reduce button margins and the spacing
main_layout.setContentsMargins(2, 2, 2, 2)
main_layout.setSpacing(2)
#main_layout.addStretch() if added before the buttons the buttons will stick to the bottom,
##add the stuff here after being added up there #--add the widget QButton to the layout
#the column view..
main_layout.addWidget(self.listWidget)
main_layout.addWidget(self.cube_btn)
###add also the other new buttons here
main_layout.addWidget(self.sphere_btn)
main_layout.addWidget(self.cone_btn)
main_layout.addWidget(self.cylinder_btn)
#if addStretch is after the buttons, the button will stay hooked at the top when resizing the window
#add the main layout itself to the primitive ui dialog
self.setLayout(main_layout)
#create method to connect buttons to commands , signals and slots??
def create_connections(self):
#click signal to each method created below
self.cube_btn.clicked.connect(self.make_cube) #
self.sphere_btn.clicked.connect(self.make_sphere)
self.cylinder_btn.clicked.connect(self.make_cylinder)
self.cone_btn.clicked.connect(self.make_list)
#self.listWidget.addItems(self.items) # this stuff is commented out cos none of this sh" works...
#####self.listWidget.addItems(brogna) #<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#for i in range(3):
#self.listWidget.addItem(self.buttonlist)
##i create method that will run comands
def make_cube(self):
cmds.polyCube()
def make_sphere(self):
print "Sphere"
#cmds.polySphere()
def make_cylinder(self):
print "Cylinder"
#cmds.polyCylinder()
def make_cone(self):
print "Cone"
#cmds.polyCone()
def make_list(self):
mylistbitch = [cmds.ls(sl=True)]
print mylistbitch
#i was a bit fustrated here, i tried to add the selection onto a list, and every subsequently selected objec in the scene would be added as #well in the list, but then i tried to simplify the whole thing to see if adding into the list would work, now it does (only when i use a list) #but it does not work 100%, since the names are not being displayed , so here i might be missing something.
#self.buttonlist.append(mylistbitch)
#addtolist = self.buttonlist
#print "addtolist e' : ", addtolist
#for i in mylistbitch:
#self.listWidget.addItem(addtolist)
self.listWidget.addItems(mylistbitch) #clicking the button cylinder now adds selection to the list, although it doesn't display the #correct names#
if __name__== "__main__":
#i put try except so maya doesnt hang up the windows if opened many times in a row.
#try close the window if it exists, other wise it will just open it
try:
ui.close()
except:
pass
ui = ssacUI()
ui.show()
