Ghosting issue in maya(Please help)
Hi there guys. listen up I have a bit of a tech issue, I can’t solve in maya. Has anyone ever encountered an issue with the ghosting in maya where any skinned mesh is unable to ghost.
Is there also a way to make the ghosted object wireframe but the mesh normal shaded.I know this is possible in max. :?:
easy way would be with layers to add the stuff you want to ghost into a templated layer.
dont know if something like you discribe already is in maya but you can also create a mel/python script for it which upon selection templates everything except the mesh you wish to paint on (because template is also an attribute on every transform and shapenode)
hope this helps
