Hi all. I’m experiencing weird behavior of Python “magic” methods and maya.cmds. Below you can see 2 versions of the code. In both versions I use string representation of the class object as first argument in cmds.connectAttr() but in second version where I have implemented __getitem__ method maya throws out # TypeError: Invalid argument 1, 'transform1.translateX'. Expected arguments of type ( , ) #
Here si the code:
import maya.cmds as mc
tr1 = mc.createNode("transform", name="transform1")
tr2 = mc.createNode("transform", name="transform2")
You are not explicitly returning anything in your __getitem__ method. All it does is print the attribute. In python when you don’t explicitly use return then it returns None.
Try directly calling your __getitem__ and assign it to a variable and you’ll see the variable contains None.
Is this an attempt to get at the underlying attrbute? Like turning myobject.translateX in code into the string "myobject.translateX"?
In a case like that, it’s better to derive from str so there’s no shenanigans and also so the object is immutable like a string (since Maya is using immutable strings, doing something else introduces wierd bugs).
Something like this will let you add pseudo-property access
class PropDescriptor:
def __init__(self, name ):
self.name = name
def __get__(self, obj, objtype=None):
return obj + "." + self.name
class AttrClass (str):
translate = PropDescriptor("translate")
test = AttrClass("top")
print (test.translate)
# top.translate
print(cmds.getAttr(test.translate))
# Result: [(0.0, 1000.1, 0.0)] #
This is used vey extensively in nodule which coincidentally I just updated to Python 3 today to allo things like connect (nodule_1.translateX, nodule_2.rotateY) or my_cube.visibility = True … pymel without the pymel, as it were.
Thanks for reply. That’s partially solves the problem. Now I need to solve multi attributes(indexed). Actually __getitem__ I was using for that purpose.
By the way nice nodule! Definitely will check it out!
