Hey guys,
I’m currently fighting with regular expressions in C# and I just can’t see what I’m doing wrong.
I get a list of Devices from an external program (adb.exe) which looks like this:
List of devices attached
R32D102RVQH device
HT13WTJ33998 device
My goal is to get an array containing only [R32D102RVQH, HT13WTJ33998]. So I’m filtering the string using a Regex, like this:
Devices = new List<Device>();
string cmdRtn = Program.ExecuteCommand("adb.exe", "devices", false);
Regex re = new Regex(@"^(.+?)\s+?device$", RegexOptions.Multiline);
MatchCollection mc = re.Matches(cmdRtn);
foreach (Match m in mc)
string test = m.Groups[0].Value;
Console.Write(test);
But no matter what I do, C# doesn’t return the correct values (the example above returns a group containing the string “List of devices attached R32D102RVQH deviceHT13WTJ33998 device”).
The worst thing is that I’ve tested my Regex on many different tools using the same pattern, text, and options and it worked every single time :S.
I’m sure that I’m doing something wrong but the more I try, the more C# regex look like voodoo magic, so if there is a wizard around, I’ll gladly welcome his help :).
Cheers!
