Directory Assistant Tool
So like the title says I created a directory assistant tool. I’ve been learning python for about 3-4 months over at the dojo and figured it was time to get some feed back on a tool i’ve created from the community. Any thoughts on it would be greatly appreciated. Cheers!!!
Unfortunately, this looks more like an academic exercise than a tool I would use. I use a script called Multi-Obj Tool to bring in/save objs to/from a directory. Referencing is so easy to do with the built in maya popup that I dont see a need to use and learn a new way.
Having a huge ‘directory assist’ label when you already set the windowTitle is another huge strike. It takes up my very valuable screen space.
If you’ve only been learning python for 3-4 four months, then good for you. While this might not be something general artists will use, it does show that you can take an idea and make it. I could see a more developed version of this on a per-company basis.
One thing I might add is a distinction between load and import, for instance, characters load while props import. what if I want 2 characters in my scene.
Keep it up man. what’s that they say, you have to make 1000 bad scripts before you get a good one?
My first read was that I felt a bit lost watching the video: context information came and went as the UI updated. it’s fine if you’re drilling down repeatedly on a set of things, but might not work so well for (a) new users or (b) people who have other things on their mind – like stopping to check a note pad in the middle of the operation.
You might want to take the opportunity to look at a few modern UI design websites and books:
http://www.amazon.com/About-Face-Essentials-Interaction-Design/dp/0470084111/ref=cm_lmf_tit_5
http://www.gui-bloopers.com/
You’ll find that the trend of the recommendations is towards keeping users ‘located’ in their task, rather than showing/hiding infromation quickly.
OTOH don’t get discouraged – on the execution side it’s a lot slicker than many of the clunky maya UI things floating around on the web. Good start, keep at it.
Thanks for the great feedback for him Berj, Shawn and Steve:)
Jason has been working hard at improving quickly and getting himself ready to be a hire-able TD and I know he appreciates the feedback.
Brad
Wow thanks for all the great responses. I have a lot of reading ahead of me. Like brad said I very much appreciate the feed back!
