I am working on a script to evaluate and report if a UV overlaps any other in a mesh. I found some great info on it if I was testing for multiple shells in a single mesh but nothing really helps when comparing each UV within a mesh. I am writing in Python and working in Maya 2014.
thanks,
MO
If you want to check if a UV point is inside another UV shell, you could try something like this:
- get all the UV shells
- make a dictionary tying each vertex to a particular shell
- get all the shells your point is NOT part of…
- for each shell , get the UV bounding box with polyEvaluate -bc2
- for any shell where your point is inside the bounding box, try the same thing with each UV face
- you’ll probably get multiple hits (the bounding boxes are usually bigger than the UV faces)…
- for each hit, you’ll need to do a detailed 2d point-in-poly check. You can code this yourself but it’s easier to use a free module like Planar.
I’ve had to do this in the past. I started off using python cmds (it was really really slow), then python API (better but still too slow on large meshes). Eventually another tech artist re-wrote it with c++ and now it is super fast.
Just checking UVs against other shells won’t find overlaps within the shell itself.
You’ll need to do a point inside poly check, but also a check for intersections. I recommend working with a copy of the mesh that has been triangulated.
Any possibility of getting this source code?
[QUOTE=rgkovach123;24006]I’ve had to do this in the past. I started off using python cmds (it was really really slow), then python API (better but still too slow on large meshes). Eventually another tech artist re-wrote it with c++ and now it is super fast.
You’ll need to do a point inside poly check, but also a check for intersections. I recommend working with a copy of the mesh that has been triangulated.[/QUOTE]
MO
Unfortunately I cannot share the source code, but you should be able to find triangle intersection and point inside triangle stuff online.
