Detect overlapping faces (OpenMaya)
Hello, is there a way to detect overlapping faces with OpenMaya? What I do now works but is terribly slow since I have to iterate over every face, create an array of the face vertices then find ones that have the same signature. Can anyone please point me to the right class?
I have to make it clear, this are NOT lamina faces since they do not have any edges connected to each other and they are of the same area and vertex positions, basically an identical polygon on top of another (normals may not face the same way). I am sure that there is a better way.
Thanks
Hmm, If I were to do that …
Rather than checking face by face, I would start by finding all vertices that are on top of each other.
To speed this up, I’d probably sort the verts by their X values. Then just group any verts with the same x-value together, and check within those groups for duplicates.
Then just find the faces that use only duplicated vertices. Once you’ve got that you can pretty easily check which faces map to the same point-groups.
I’m fairly certain this isn’t the 100% best algorithm, but it’s probably a “good enough in practice” one.
All that data’s available on MFnMesh, or through an iterator, and it’s available many ways.
My own personal preference would probably be to use the raw face connectivity data available from MFnMesh.getVertices, and the vertex position data from MFnMesh.getPoints.
This isn’t too hard to do, but there are a couple important things you need to get right.
Firstly, avoid creating large python lists inside of loops when you have large amounts of data to iterate over (like mesh faces). Python in itself is actually pretty fast, but the memory overhead in creating large dynamic lists in every loop iteration is what will cause most of your slowdown. Adding to existing lists is usually OK, but copying, combining, or removing from lists (not by index) can get heavy because it is actually iterating under the hood.
Instead, use an iterator from the API, like MItMeshPolygon. The difference here is that the iterator doesn’t construct any new lists at all, but rather gives you a handle to each polygon in memory as you’re iterating through the loop, so the overhead is minimal. Or, even better, if you can get the lists you need from any of the get functions on MFnMesh, they’re created in C++ and all you have to do is read their data in python. I’ve used this method to process uvs for meshes with 30k+ verts in under 1/8th a second with no issues. For your use case though, I think MItMeshPolygon is going to be the easiest way to access the data you need. Particularly I’d look at the following methods:
MItMeshPolygon.index()         # get the index of the current face
MItMeshPolygon.getVertices()   # get the face-relative indices of the current face's verts
MItMeshPolygon.vertexIndex()   # get the object-relative indices of a particular vert
MItMeshPolygon.getPoints()     # get the position of all the verts
You can use MItMeshPolygon like so…
# get dag path of object...
meshPolyIter = om.MItMeshPolygon(dagPath)
while not meshPolyIter.isDone():
    # do work here...
    meshPolyIter.next()
Documentation for MItMeshPolygon is here
Ok.
Now that the API part of this is out of the way, let’s talk algorithms. I’m going to be using pseudocode from here on because frankly, it’s easier that way.
Essentially, a duplicate face is one that shared all its verts with at least one other face on the mesh (by your definition here). The most straightforward, naive way to find faces that match that criteria is by comparing every face to every other face:
for every face on mesh:
    for every otherFace on mesh:
        if face.vertIDs matches otherFace.vertIDs:
            // we found a duplicate face, so track it
            duplicates.add(otherFace.faceID)
Now, if you understand computational complexity, this method is O(n^2), which is a fancy way of saying that you have to iterate over the number of faces times the number of faces. This is going to be really slow for high poly meshes because the computation time of the algorithm increases exponentially as the number of polys grows.
So that means we’ve gotta get rid of that inner loop. Instead, let’s try storing each face as we iterate through them the first time. For every face, we can store it by picking an arbitrary axis and using the ID of it’s most positive vert along that axis. That way when we go to compare faces, we only have to compare with faces that we know share the same topmost vert as the current face. This works because we can assume that duplicate faces are overlapping exactly. Again, the actual axis you use is arbitrary, so I’m just gonna use the Y axis.
// keep in mind, this is pseudocode
facesDictionaryByID = dictionary()
for every face in mesh:
    maxY = max(v.y for v in face.verts)
    topmostVertID = vert where vert.y == maxY
    if topmostVertID in facesDictionaryByID:
        otherFaces = facesDictionaryByID[topmostVertID]
        for otherFace in otherFaces:
            if all face.vertPositions match otherFace.vertPositions:
                duplicates.add(face)
                break (go back to outer loop to look for more dupes)
        if no duplicate was found:
            // add the current face to the list of faces with a matching topmost vert
            facesDictionaryByID[topmostVertID].append(face)
    else:
        facesDictionaryByID[topmostVertID] = list(face)
Now we still have an inner loop, but it’s only iterating over faces which could be potential duplicates for the current one, which is going to be a relatively very small number. The important point is that now we aren’t checking against every other face, we’re only checking a few other faces, if any, per face.
EDIT: I also want to note that storing faces based on a particular vert index rather than position also has the benefit of allowing us to use an int instead of a float as a dictionary key and thus avoid false negatives due to floating-point error.
However, there’s a caveat. The speed it all runs depends on how you check whether the topmostVertID value is in that dictionary.
If you use the python keyword in or use dictionary.keys() then you’re actually creating a new list of all the keys currently in the dictionary, and python will try to determine if it contains matching values by iterating over it. However, accessing the value via dictionary.has_key() [the in keyword] or dictionary.get() doesn’t have to iterate over all its values since it uses a hash lookup (you don’t have to know what that means, just that it’s fast).
If you’re still following me when I talk about computational complexity, the dictionary.keys() version is expensive because it causes an iteration over a list that gets bigger each time we go through the loop. This runs in O(n(n+1)/2), which is effectively not much better than O(n^2) - what we had with the naive solution. But since [using the in keyword on dictionaries] dictionary.has_key() and dictionary.get() functions are considered to run in O(1) time (constant), then effectively, their usage reduces the algorithm to O(n) time, which is not too shabby. It means that we only need to go through the loop about once for every poly, instead of that number squared.
Hopefully you find all of this helpful and not confusing. This turned out to be a much longer post than I meant for it to and it got a bit computer-sciency.
EDIT: in for dictionaries is actually O(1) in Python 2.7, so using it is encouraged. Also, dictionary.has_key() still works in Python 2.7, but is deprecated and should in best practice be avoided as it was removed in later versions.
Sorry for nitpicking on what is otherwise a great and informative post! :smile: But there’s a couple of misconceptions that should be corrected:
Checking membership of a dictionary in Python should be done by if item in my_dict: and this does not create a new list of keys or iterate in any way, it’s a hash lookup. Don’t use my_dict.has_key() as this has been deprecated since Python 2.3 ish and was removed in Python 3.
Using the in keyword is totally fine and performs at O(1), the real thing to avoid is my_dict.keys() as in don’t use if item in my_dict.keys(): because as you say, this is O(n).
Ah, I see. I knew that the in keyword had replaced my_dict.has_key() and was O(1) in Python 3, but I didn’t know that was already the case in Python 2.7 (which is what maya uses). I’ll edit my post. Thanks!
If the Maya version is lower than 2020.3, then .next() without the required None argument will throw an error !
New in the Maya 2020.3 devkit :
“The call to face_it.next(0) has been changed to face_it.next()”.
Notably, prior to this, Maya Python API documentation never indicated that face_it.next () needed the required None argument.
So if you need to support Maya versions before and after 2020.3 in your code, be aware of these differences in syntax.
