Hey guys,
My first post here!! Awesome forum!!
So, I’m working on a Lights Manager for our lighting team. Basically an Attribute Spreadsheet specifically for lighting, some render engines and our pipeline. I’m using custom delegates to create specific editors on a TableView widget. I need some sort of editor to be able to work with a cell on my table which contains color info so I went with QColorDialog.
Problem is when I pass QColorDialog as an editor to my custom delegate, it doesn’t work. I cheated a lot (I know it’s wrong, but just wanted to understand what was going on) and got it to sort of work but it doesn’t take into account user input regarding Accepting or Canceling the dialog edits.
Could you guys please point me in the right direction on how to proceed with this problem? Some possible ways I’ll research: QItemEditorFactory and QItemEditorCreatorBase, the starrating.py example included with PySide (which is complex, but seems to be the most customizable).
Thanks in advance for all the help you can give me!!
The summarized code for the delegate is this:
class PropertiesDelegate(QtGui.QItemDelegate):
super(PropertiesDelegate, self).__init__(parent)
def createEditor(self, parent, option, index):
dataList = index.model().getDataList()
currentValue = dataList[index.row()][index.column()]
thisColor = QtGui.QColor(currentValue)
colorDialog = QtGui.QColorDialog(self.parent)
colorDialog.setCurrentColor(thisColor)
return colorDialog
def setModelData(self, editor, model, index):
modelHeaders = index.model().getHeaders()
if modelHeaders[index.column()] == "default":
uiControl = dataList[index.row()][2]
if uiControl == "colorswatch":
model.setData(index, editor.colorSelected().name()) #If I use selectedColor(), in this particular case, it always returns black
else:
QtGui.QItemDelegate.setModelData(self, editor, model, index)
def setEditorData(self, editor, index):
QtGui.QItemDelegate.setEditorData(self, editor, index)
