got this about as far as I need it for now
Hi prolow,
This is awesome! I have been wanting to do the same thing. Can you give me some tips?
I can tell you that MFnNurbsCurve seems lacking some of the object editing functions that MFnMesh has like add or delete components. I have yet to figure how to properly modify anything other than the component positions. Instead resorted to just creating a new curve and deleting the old, every time I cut or grow the curves.
Hi prolow,
I have three additional questions…
- What brush are you using to select and translate the cvs? Are you drawing your own or using something like the artisan brush?
- Are you using a ray intersect function of some type to determine which cvs are under your cursor?
- How are you getting the the cursor movement (i.e., for translating the cvs)? Are you using QT in some way to capture the mouse location/movement?
it’s a mix of python maya.cmds and maya.OpenMaya API.
Using draggerContext gives me the mouse point in view screen space.
I project the cv positions into screen space using M3dView.worldToView.
Then determine what cvs are under my “brush”, which is drawn with openGL calls to the MHardwareRenderer.
I get the translation by converting the screen space mouse coords to world space using M3dView.worldToView.
Which gives me points(mouseWorldPointA,B) and a view direction vector(DirectionA,B). Earlier when I found what cvs were under my cursor I stored their average position(center).
A is current mouse position
B is the previous mouse position
zDist = center.distanceTo(mouseWorldPointA)
movePointA = (DirectionA * zDist) + om.MVector(mouseWorldPointA)
movePointB = (DirectionB * zDist) + om.MVector(mouseWorldPointB)
moveVector = movePointB - movePointA
prolow,
That’s awesome. Thanks for the pointers. I am anxious to give them a try.
