in maya api, how do you make a vert selection on a mesh and then store the selection in a MFloatPointArray?.
and also, is it possible to have a list of verts in an array that you have already created eg. vertList = [vert23,vert35,vert67 etc…] and then transform this list into an MFloatPointArray?
Hello there. Here’s an answer to the first part of your question.
import maya.OpenMaya as om
selectionList = om.MSelectionList()
om.MGlobal.getActiveSelectionList(selectionList)
pointArray = om.MFloatPointArray()
for i in range(selectionList.length()):
mdag = om.MDagPath()
components = om.MObject()
selectionList.getDagPath(i, mdag, components)
if not components.hasFn(om.MFn.kMeshVertComponent):
continue
vtxIter = om.MItMeshVertex(mdag, components)
while not vtxIter.isDone():
pos = vtxIter.position()
pointArray.append(om.MFloatPoint(pos))
vtxIter.next()
print pointArray.length()
As to the second part of your question, I don’t have any code for you, but I can tell you that it is possible to take a list of verts and convert them to an MFloatPointArray.
