Create Curve from Selected Objects [Python]
Hey Everyone, I am converting some scripts from MEL to Python. The script working on right now creates a curve based off the selected Objects
I am having trouble converting the last the last bit of code(put notes in the scripts).
Anyone know the proper way to write it in python?
Here is the working MEL script
global proc CurveFromObjs () {
	string $jnt[] = `ls -sl`;
	vector $storePositions[];
	int $x = 0;
	for ($i in $jnt)
		$storePositions[$x] = `xform -query -worldSpace -translation $i`;
		$x++;
	int $degree = 3; //<-- incase u want to change the degree type
//area that needs to be converted to python correctly
	string $buildCurve = ("curve -d " + $degree);
		for ($each in $storePositions)
		$buildCurve += (" -p " + $each);
	eval $buildCurve;
Here is the Python Code I have so far
selObj = cmds.ls(selection = True)
selObjSize = len(selObj)
storePositions= []
crvDegree = 3
##get positions
for i in selObj:
	sp = cmds.xform (i ,query= True, worldSpace=True,translation=True  )
	print storePositions
#area I am having trouble with
for each in storePositions:
	 buildCurve = cmds.curve(d = crvDegree,p=[( each, each, each )])
sel = cmds.ls(sl=True)
curve_degree = 3 # cubic curve
positions = [cmds.xform(obj, q=True, ws=True, translation=True) for obj in sel]
my_curve = cmds.curve(d=curve_degree, p=positions)
It’s pretty simple to use Python’s list comprehension to get a list of world space positions for the selected objects.
That list will be a nested list of [x, y, z] positions – which is essentially the same thing that the cmds.curve command expects for the ‘point’ argument.
Hopefully that helps!
Thanks! Exactly what I was looking for!
