Hey everyone,
When I keyframe more than one controller at say 1, then key another pose at a different keyframe frame at 10. Then copy all of the keys from 1 to 20, it’s a different pose.
Anyone have any ideas or suggestions.
What i’ve found out is that it will copy the first controllers keyframe values to the rest of the controllers.
Um. it might just be that you need to open your paste option box and set paste method to merge instead of insert. It seems to default to insert which for seems to be useless. This of course assumes you’re doing this in the graph editor. Not sure what’s going on if you’re just working on your time slider.
Hopefully its that simple. I hope I haven’t misinterpreted the problem.
