Spent an hour figuring out why some mesh properties turned out wrong after we optimized some property bits (we’re storing shader “property” features as bits in a single INT32).
Type this in 3dsmax’s listener:
“2147483655” as integer64
and what do you get back? (L just means the number is “LONG”)
2147483648L
E.g, this DOES work:
i = 2147483648L
iLarge = i * 4
the value of iLarge is 8589934592L
SamiV. (I swear to never ever again try to just quickly make some utility in MaxScript while I could do it for real in Python… :)Python now…)
Same issue here… did you find a work-around / fix for this?
It’s been a while, but I’m pretty sure I came up with some workaround since I got the thing running…
Perhaps I just truncated the string into two byte segments and rebuilt the int64 manually with powers of two? Can’t recall anymore, sorry. I can dig into our Perforce history around the time I made the post if you need this and the thing is still borked in 2012.
SamiV.
other options:
ru = stringstream “2147483655L”
readValue ru
–2147483655L
“2147483655L” as integer64
Ah thanks Ruramuq! Your workaround is much nicer than mine.
Samiv.
