Connect maya 2015 to Team Foundation Server
Hey all,
Our team just moved to Maya 2015 and I’m currently investigating how to access workspace information in Team Foundation Server. I’ve read this version of Maya has a tighter integration with .net so I’m hoping there will be a straightforward solution. Any advice or examples of how this is done is much appreciated.
Thanks!
Rusty
Maya.net is OK. You’d have to write it as a plugin using the managed plugin API, which is not too bad – docs are here: Autodesk Maya API Documentation and there’s a good plugin wizard to get you started Autodesk Maya API Documentation (those are 2014 links but should be the same in 2015)
TFS is aaaaaawwwwwwffffulllllllll. I wish you luck.
Hey!
Thanks for the response! If its the only solution, it sounds like I’ll need to dive into it as we’re required to use TFS. I noticed that both of your links went to the same location - was that intentional? Thanks for bit of advice!
Rusty
