I have run into some errors in which my function seems to be reading in both if and else statements that I have created, instead of either one at a time.
So what I am trying to do is that, if it reads the importing file, first line/first character, if it is not v, it will prompts a warning and asked the user to re-import the relevant file. Else, if the file is correct, it will go on and creates the locators and group it.
Example - The file line in the correct obj file should be: v -0.6110637188 0.0093309134 8.1327419281
As soon as I tried another obj file in which it first line is started off as # This is a testing file… I was prompted with tons of errors as follows:
# Warning: Please import in a relevant Point Cloud Obj #
This part works if importing the right point cloud
# Failed to read file information
# Error: list index out of range
# File "<maya console>", line 62, in <module>
# File "<maya console>", line 16, in __init__
# File "<maya console>", line 58, in processLine
# IndexError: list index out of range #
As you can see in the error log, it is printing the statement that I have inputted in both if and else statements. Additionally, it is creating out the locators as well which it should not be. This is my code:
import sys, os
import string
class ObjCloud():
def __init__(self):
try:
fileHandle = open("/user_data/aaa.obj","r")
filePath = os.path.basename(fileHandle.name)
fileName = os.path.splitext(filePath)[0]
for line in fileHandle:
self.processLine(line)
fileHandle.close()
except:
sys.stderr.write( "Failed to read file information
raise
cmds.select("locator*")
objGroup = cmds.group(n=("pointCloud_" + fileName))
cmds.xform(os=True, piv=(0, 0, 0))
cmds.scale(0.01, 0.01, 0.01)
cmds.delete(constructionHistory=True)
cmds.select(objGroup)
cmds.group(n="cameraTrack")
cmds.scale(10, 10, 10)
def processLine(self, line):
if(line[0] != "v"):
cmds.warning("Please import in a relevant Point Cloud Obj")
else:
brokenString = string.split(line)
cmds.spaceLocator(absolute=True, position=(\
float(brokenString[1])*100\
, float(brokenString[2])*100\
, float(brokenString[3])*100))
cmds.CenterPivot()
