I’ve been running into a bunch of related problems with cut and paste operations in Maya 2015 and I’m wondering if anybody has seen or solved these before.
- Rich text pasted into Maya
It’s pretty well known that this is less than perfect - you can’t, for example, paste text from PyCharm into Maya (a giant pain in the butt).
I tried the solution from Nathan Horne, but that has the nasty side effect of disabling cut-and-paste of files in windows while Maya is running.
- Cutting text using win32
I’ve used Pyperclip for several years with no problems to do python cut-and-paste operations. However in Maya 2015, paste does not work. Running the same code outside of a Maya environment works, however.
I’m assuming these are related, though that’s just an assumption.
Has anybody got a good workaround for either or both of these?
