Center of a circular arc
anyone here can help me,
I am trying to get the centre point position of a 3-point arc in 3d space.
but I am really bad with vector math.
I google for a long time, but no luck.
Screenshot 2022-06-28 215644
Are you trying to solve the math, or just find the point?
There is a built-in 3 point arc tool in Maya. Create arcs
Create → Curve Tools → Three Point Circular Arc
hi clesage, I am trying to solve the math,
I can get the point I want with Three-Point Circular Arc,
but I want to make a script without select points manually,
the problem I have currently I can create node and create arc without any problem,
but it just won’t give me the centre point of the circular arc.
the pivot point will only stay at 0,0,0
Cool, just checking since you said you were bad at math and found nothing in google.
All the same though, when you create a makeThreePointCircularArc node, it certainly does have an output .center that you can query.
(Oddly, if you connect a transform to it, it doesn’t update automatically when the 3 points are modified. But you can force it to refresh by force reconnecting it.)
thanks, because in my code I acutally freeze(kill) the hitsory, that’s why . you have my day :slight_smile:
No problem.
Another obstacle to watch out for. When you are running your code, I’m noticing that the arc node won’t return a center until the UI is refreshed.
p1 = (0,1,1)
p2 = (0,2,3)
p3 = (0,4,5)
newNode = cmds.createNode('makeThreePointCircularArc')
cmds.setAttr(newNode + '.pt1', p1[0], p1[1], p1[2])
cmds.setAttr(newNode + '.pt2', p2[0], p2[1], p2[2])
cmds.setAttr(newNode + '.pt3', p3[0], p3[1], p3[2])
cmds.setAttr(newNode + '.d', 3)
cmds.setAttr(newNode + '.s', 4)
newCurve = cmds.createNode('nurbsCurve')
cmds.connectAttr(newNode + '.oc', newCurve + '.cr')
#cmds.delete(ch=1)
transformNode = cmds.listRelatives(newCurve, fullPath=True, parent=True)
cmds.rename(transformNode, 'arcCurve')
print(cmds.getAttr(newNode + '.center'))
# RESULT IS [(0,0,0)]
cmds.refresh()
# RESULT IS [(0.0, 8.499999999999979, -1.499999999999985)]
yp, refresh UI is a bit annoying but will do the job for now. thank you so much
you could do it completely through vector math like this
def rayPlaneIntersection(rayOrigin: Vector, rayDirection: Vector, planeOrigin: Vector, planeNormal: Vector) -> Vector:
    distance = ((rayOrigin - planeOrigin) * planeNormal.normal())
    return rayOrigin - rayDirection * (distance / (rayDirection * planeNormal))
def centerOfCircle(point1: Vector, point2: Vector, point3: Vector) -> Vector:
    vec1 = point1 - point2
    vec2 = point3 - point2
    cross1 = vec1.normal() ^ vec2.normal()
    aim1 = vec1.normal() ^ cross1
    center1 = (vec1 * .5) + point2
    center2 = (vec2 * .5) + point2
    centerPoint = rayPlaneIntersection(center1, aim1, center2, vec2.normal())
    return centerPoint
