I could not find how to Enable/Disable Setup Animation mode toggle using max script.
Is this the solution:
<CATParent>.CATMode Integer default: 0 – integer
I select CatParent and use:
$.CATMode 1
and result is:
– Type error: Call needs function or class, got: 0
any help please?
JHN
2
It’s a property (not a method or function) so probably
$.CATMode = 1
would do it.
-Johan
Thanks Johan
I used that. it returns 1(or 0) but in the panel it will not change CAT mode. :?:
Edit:
It actually changes, but we can see results when we switch off and then come back to motion panel.
thanks again
The hack I use to go around this issue is switching the “LayerEnabled” off and on again (or the opposite) through scripting.
catRig = $ctrl_cat – this is your cat control
catRig.catmode = 0 – 0 or 1
curLayerState = catRig.layers.controller[1].controller.LayerEnabled
catRig.layers.controller[1].controller.LayerEnabled = not curLayerState
catRig.layers.controller[1].controller.LayerEnabled = curLayerState
I hope it works for you.
Cheers,
Seigi
Very good! this way you suggested works even for those cases that motion do not play as it should
thank you very much Seigi.
