I wrote a mll plugin for maya and use qt in it (I use maya 2011 x64 on windows and Qt opensource 4.5.3, build with vs2008).
There’s a QMainFrame in my plugin and some actions with shortcut added to the widget.
When I run it in maya, I can’t use any hotkey to invoke the my actions. For example, I set the Ctrl+n to my own “new file” action, but after I pressed Ctrl+n in maya (I focused on my widget), it just made a new maya scene, not my “new file” action. Then I tried to change the hotkey which isn’t existing in maya, like Ctrl+e, but failed also.
But I start my widget in standalone QApplication, I can use all my hotkeys!
I too am currently struggling with this issue. Looking at the setFocusPolicy as suggested doesn’t solve it. I suspect it has something to do with Maya hijacking the shortcut signals. Afterall, Maya’s UI is now using the same Qt shortcut system.
I am going to try the QKeyEvent directly and see how that goes…
As I suspected, you have reimplement the keyPressEvent for each widget you want to specify hotkeys for.
[pseudocode]
class Window():
def __init__():
# this assumes using uic to load a ui file
# that has centralwidget as the main window
# and tableview as a child
self.centralwidget.setFocusPolicy(qt.StrongFocus)
self.centralwidget.keyPressEvent = self.mainWindowKeyEvent
self.tableview.keyPressEvent = self.tableKeyEvent
def mainWindowKeyEvent(self, event):
pass
# this just accepts all keystrokes and does nothing with them
# so that they don't get propagated on to Maya's hotkeys
def tableKeyEvent(self, event):
if event.key() == Qt.[keystroke]:
[do something interesting]
event.accept() # make sure the event stops here
else:
# make sure any usual tableview hotkeys still get dealt with
QtGui.QTableView.keyPressEvent(self.tableview, event)
