Can`t add two rows in database during one connection
Do I need to close connection every time I add/delete something in the database table?
Here is the code, adding a second Project object rise error (probably because second time the cursor.lastrowid returns the same id as first):
import sqlite3
DB = 'C:/temp/projects.db'
class Project:
    def __init__(self, project_name):
        self.id = None
        self.name = project_name
def add_project(project):
    cursor.execute("INSERT INTO projects VALUES (:id, :name)",
                   {'id': cursor.lastrowid,
                    'name': project.name})
    connection.commit()
connection = sqlite3.connect(DB)
cursor = connection.cursor()
cursor.execute('''CREATE TABLE IF NOT EXISTS projects (
                id integer primary key autoincrement,
                name text
connection.commit()
project = Project('TESTER_1')
print '1 created'
# connection.close()
# connection = sqlite3.connect(DB)
# cursor = connection.cursor()
project = Project('TESTER_2')
print '2 created'
If I close connection and create a new one (uncomment lines) the second item is working fine.
ordinarily you should not have to close and reopen like that. I think sqllite defaults to auto-commit as well, so you should not even have to call connection.commit() either (see python - Why doesn’t SQLite require a commit() call to save data? - Stack Overflow)
