C# Info: StringBuilder vs String Concatenation example,
Hello,
So I have a project at home I work on (normally in the morning before work). Long story short, it involves a class that has methods for spitting out things mainly for shader development.
So in order to show why/how StringBuilder is faster for concatenation than just strings (stringBuilder.Append(“example”) vs string += “example”, etc.), I wrote this little C# test yesterday.
The thing is, since strings are immutable, concatenation just creates a new string, so often people do not realize how many new strings are created.
Long story short, 20000 appends with stringbuilder takes 4 milliseconds vs 1016 milliseconds for concatenations (depending on your machine),
If you find some error in my logic, let me know :):
[highlight=C#]
using System;
using System.Collections.Generic;
using System.Text;
using System.Diagnostics;
namespace ConsoleApplication1
class Program
static void Main(string[] args)
int numberOfLoops = 20000;
        Stopwatch stringBuilderTimer = Stopwatch.StartNew();
        stringBuilderAppend(numberOfLoops);
        stringBuilderTimer.Stop();
        Console.WriteLine("{0} appends with the string builder took {1} milliseconds.
", numberOfLoops, stringBuilderTimer.ElapsedMilliseconds);
        Stopwatch stringConcatTimer = Stopwatch.StartNew();
        stringConcat(numberOfLoops);
        stringConcatTimer.Stop();
        Console.WriteLine("{0} concatenations with the string builder took {1} milliseconds.
", numberOfLoops, stringConcatTimer.ElapsedMilliseconds);
Console.ReadLine();
    private static void stringBuilderAppend(int numberIterations)
        StringBuilder aString = new StringBuilder();
        for (int i = 0; i < numberIterations; i++)
            aString.Append(i.ToString());
    private static void stringConcat(int numberIterations)
        string aString = null;
            aString += (i.ToString());
Of course, if it's just few concatenations, it may not be worth the effort, but keep it in mind the larger you go. :):
(Side Note: This may be "old-hat" for some)
http://blogs.msdn.com/b/ricom/archive/2003/12/02/40778.aspx
Thanks for the link.
