Blendshape techniques
Hi guys ,
Recently i came across this page, Blendshape techniques.
http://petershipkov.com/tutorials/blendShapes/blendShapes.htm
I done everything like he said, but in the end he told like “Select the blendShape node and apply the “Display Intermediate Objects” command inside the Deform menu.”
If select the blendshape node and apply the Intermediate object i’m getting an error
"// Error: file: C:/Program Files/Autodesk/Maya2013/scripts/others/displayInterObjects.mel line 404: Found no intermediate objects. //
Can u you guys help me.I do no why i’m getting this error.Is there any solution for it.
Thank You,
Sabarishwar
http://lrsabari.blogspot.in/
I’m guessing an object (ex: poly) that has a deformer needs to be selected before using Display Intermediate Objects in Edit Deformers menu. I’m not sure if that is helpful. I made a video and script a while ago that may be helpful http://vimeo.com/31522738, https://docs.google.com/document/pub?id=1ynnzKddXdNkPap5epHI3sh_CdkYMv5Hu_VYvMDxD3Ts
Also check out this great post by Louis Vottero:
http://forums.cgsociety.org/archive/index.php/t-222558.html
and his intermediate toggle script:
http://www.creativecrash.com/maya/script/intertoggle-mel
And Firat Enderoglu’s Discussions on Intermediate object
And of course Peter Shipkov’s amazing work (petershipkov dot com)
cheers,
-Nate
Thx Nate, i’ll check out nd i come back.
