Auto clav and ik fk arm snap
Hi all,
Does anyone know of an autoclav solution with possibility to move it manually too which is not giving problems when we need to match ik to fk arm and viceversa?
If I have autoclav on with my solution it drags with it the ik arm so then when I snap the ik arm to the fk arm via script I have problems.
Any idea or solution for this? Need auto clav on and possibiity to snap ik to fk arm and viceversa
thanks a lot in advance
The easiest way to probably do it would be to set up the auto fk/ik with a triple joint chain, then have the auto-clav simply react to the positioning of the bind chain. While you’re at it, you may also want to set up an auto-scapula, depending on your needs.
