I want to rotate an object around an arbitrary axis. As a first step I am aligning the x-axis of the object with the vector and then I will rotate the object around x-axis. And in the end rotate the object back by inverse of first step.
How should I approach this using Maya’s node network?
This vector is basically the rolling axis and I am calculating it based on the direction of movement (vector). Rolling axis is basically a perpendicular vector.
The simplest logic I read and understood mathematically is to snap the object’s one axis onto this vector by multiplying with a rotation matrix. Then rotate the object around that axis. And in the end just multiply with inverse matrix of the first rotation matrix to put things back.
i.e. R = AMA’
A = rotation matrix to align x-axis with vector
M = rotation around x axis
A’ = inverse of A
Do I understand this right mathematically?
The challenge is also to do this using maya nodes if possible.
That’s a great article. Explains it very clearly.
I can calculate angles this way using an expression node. That option is open, but I am trying to reduce load on expression node.
I could use vector product node, but I still won’t have acos function in node. May be I could use another expression node just for that.
Hmmm.
On a side note, I have met Malcolm once. He used to teach classes at SCAD when I was there.
I suppose it would be easy enough to write your own math node to do it. It’s not quite cheating, but it would be nice to find a native maya node that could help you.
