3dsmax.ini userprofile userfolder
I work in a small archviz studio and i am trying to streamline workflow and settings etc.
I was having a look at the 3dsmax.ini file in order to try to standardize the max settings on everybodies computer. In general it would work out fine if i would copy it over to other computers so that people would have the same settings as on my computer.
But i am running into a problem now. The users that are loged in with a different username get errors when using my ini file. This because severall paths in the ini file are set to my username instead of their name.
For example:
Temp=C:\Documents and Settings\admin\Local Settings\Application Data\Autodesk\3dsMaxDesign\2010 - 64bit\enu emp
In this path “admin” is my username. But if joe would log in with his username “joe” then this name would need to be replaced.
I was trying to replace the username with %username%, as you would do in a batchscript for example. But that did not work out. So i was wondering if there is a simple solution to this problem.
Perhaps i need to set max to look for the ini file the root of the max install?
And as of next week we will be setting up a renderfarm. So i was wondering if there is also a simple setup to be sure that all renderservers will be running the same 3dsmax.ini file.
Any help is more then welcome.
Best regards,
Joost
Edit the Install Settings.ini file in the root of your 3dsmax install folder.
[Least User Privilege]
useUserProfiles=0
This will make 3dsMax act like it use to in pre-v9 days :slight_smile:
Hello Mike,
Thank you for your reply.
I was also thinking of setting the useUserProfiles to 0.
Loocas Duber also pointed out to me that i could use 3ds max command-line swith to include a other ini file. So i guess either way i should be able to figure out a way of implementing a centralized ini.
cheers,
Joost
Hi Mike,
Sorry, one more question. Do you make use of the useUserProfiles=0 in your office?
Best regards,
Joost
Woah… Thanks for the tip Mike. I wish I had just known that when Max9 came and would have saved a lot of headache… Don’t tell me that was in the readme or something… :slight_smile:
SamiV.
[font=宋体]The hostess apologized to her unexpected cheap wow goldguest for serving an apple-pie without any cheese.buy cheap wow gold The little boy of the family left the room buy cheap wow goldquietly for a moment and returned with a piece buy cheap wow gold of cheese which he laid on the guest’s plate. The visitor smiled, put the cheese into his mouth and then said: “You must buy cheap wow gold have better eyes than your mother, sonny. Where did you find the cheese?” “In the rat-trap, sir,” replied the boy. [/font]
