[3dsmax] Fast way to kill animation?
Hi there,
i am currently looking into ways to remove animation from quite a lot of objects fast. The implementation that is in place currently takes up to 40 minutes or longer for some of our production scenes.
Currently there was a rather naive implementation:
select objects
maxOps.deleteSelectedAnimation()
I have played with various approaches including trackbar filtering to narrow things down etc. The fastest i currently have is this:
ts = timestamp()
deletekeys objects #allkeys
enableSceneRedraw()
format "Time: %ms
" (timestamp()-ts)
Now with a test scene i am generating this still takes 139892ms (compared to 207513ms using the current implementation)
Anyone has any ideas how to make that faster? That is still way too slow :frowning: It seems kind of ridiculous to wait over 2 minutes to delete
some animation. From the current numbers i expect that to still be around 15 minutes in production scenes.
Here is the script i use to generate a testcase scene:
	seed 0
	delete objects
	smat = Standard()
	cont = Bezier_Float()
	addnewkey cont 50f
	smat.opacity.controller = cont
	mmat = MultiMaterial numsubs:2
	mmat[2] = smat
	attr = attributes attr
		parameters params
			value type:#float
	modi = NoiseModifier()
	modi.scale.controller = cont
	text = Noise()
	text.size.controller = cont
	empt = EmptyModifier()
	custattributes.add empt attr
	empt.attr.value.controller = cont
	cmat = Standard()
	custattributes.add cmat attr
	cmat.attr.value.controller = cont
	mats = #(smat, mmat, Standard diffusemap:text, cmat, Standard(), Standard())
	nodes = for k=1 to 5000 do
		b = box()
		if (random 1 10) < 5 do b.mat = mats[random 1 mats.count]
		if (random 1 10) < 3 do b.controller.pos.controller[1].controller = cont
		if (random 1 10) < 2 do addmodifier b modi
		if (random 1 10) > 8 do addmodifier b empt
		if (random 1 10) > 9 do
			custattributes.add b attr baseobject:on
			b.baseobject.value.controller = cont
			custattributes.add b attr baseobject:off
			b.value.controller = cont
		if (random 1 10) > 7 do b.width.controller = cont
		if (random 1 10) < 1 do
			converttomesh b
			animatevertex b #all
			addnewkey b.baseobject[#master_point_controller].vertex_1.controller 40f
	gc()
Any ideas would be greatly appreciated.
Cheers,
Thorsten
Oh one thing i forgot: If i select all objects manually, select all keys in the timeline and hit “Del”, then the animation is removed within 3 seconds. Any idea how to mimic this behaviour?
Cheers,
Thorsten
Okay, got something that brings substantial gains. In the production scene i am still seeing 3 minutes to remove all animation, but that’s a LOT better than the 30 mins. I am open to other suggestions of course!
      fn myCallbackFilterFunction theAnimatable theParent theSubAnimIndex theGrandParent theNode =
                  if isController theanimatable and theanimatable.keys.count>0 then
				deleteKeys theanimatable #allKeys
                        false
                  else true
      with redraw off
            trackbar.filter = #all
            local filtind = maxops.trackbar.registerFilter myCallbackFilterFunction undefined "." 1 active:on
            select objects
            maxops.trackbar.redraw forceRedraw:on
            maxops.trackbar.unregisterfilter filtind
            clearSelection()
Cheers,
Thorsten
