Hey all - I’m starting to get my feet wet with 3dsMax and Python (looking to extend some of our Maya frameworks over to max).
I’m trying something simple - exporting an FBX with custom settings to disk. I want to do it without any dialogs - but I cannot seem to find a way around it.
Unfortunately, this doesn’t seem to work - I always get the FBX export prompt. Any ideas? My maxscript is SUPER rusty, so if there is another way, forgive me.
Your maxscript is totally fine - it’s pymxs’s dodgy way of integrating “name values” that’s the problem. Name Values are basically the property flags with a “#” in front of them. Why are some name values and others just properties? I don’t know. I assume someone does, but not this guy.
Anyway, to get it working in pymxs, rather than do the logical thing which you did (noPrompt = True), you have to do this:
pymxs.runtime.Name("noPrompt")
Instead. That effectively shoves “#noPrompt” in there, which is what you want. SelectedOnly and Using should be fine as assignments like you have it.
Edit: To clarify, your final line should now read…
