3dsmax question: Does anyone know in which config file the “configure buttons sets” for the utilities panel are saved ?
It is saved within the 3dsmax.in.
In Vista it could likely be in the following location.
c:/users/your_name/AppData/Local/Autodesk/3dsmax/2010 - 32bit/enu/3dsmax.ini
It is under the [Utility Sets] section
The numbers after ModSetEntry0 seem to relate to the entries you have applied. If you save a temp copy of the current ini file then modify the utility sets and diff the temp ini file to the updated ini file you will see the numbers change. I don’t know how to classify the numbers other than change the button and see what they become.
Thanks !
