[3dsmax 2013- python] Using FBX exporter?
Trying to run the FBX exporter with :
from Py3dsMax import mxs
mxs.pluginManager.loadClass FbxExporter
But it always commit an error.
Finally also trying the example from the documentation :
mxs.FBXExporterSetParam "Cameras" False
…and also having an error, but if by chance I find a fix to the first issue, it should work.
All those function are running well using the maxscript Listener without the mxs.*
Finally, reading the documentation, there is nothing to setup the full path file to export?
From FBX maya, it uses to be pretty easy with the “-f” flag…
Any idea? :frowning:
Thanks…
Alright, just found one answer on the py3dsmax doc :
maxscript code
Sphere name:"MySphere"
In the Python Logger, I would type:
python code
 mxs.Sphere( name = "MySphere" )
Then :
should be :
mxs.FBXExporterSetParam("Cameras", False)
EDIT :
FInally :
should be
mxs.pluginManager.loadClass(FbxExporter)
Sorry guys… I keep fighting with maxscript >> python…
Trying to do an export setting up the FBX options first and then to export without the settings pop up…
From the maxscript :
exportFile exportpathFull #noPrompt selectedOnly:true using:theClasses[8]
Then I tried a few conversion like the following :
fn = "C:\	est.fbx"
mxs.exportFile((fn), mxs.namify('noPrompt'), selectedOnly(False), using(exporterPlugin.classes[8]))
or
mxs.exportFile(fn)(mxs.namify(mxs.noPrompt)) (mxs.selectedOnly(False)) (msx.using(exporterPlugin.classes[8]))
But the FBX window always pop… :(:
Any idea?
Made a few research over google and the blur-dev wiki, but really nothing concerning the # conversion to python…
The only thing I found is the following here :
render renderType:#bakeSelected
Python :
mxs.render( renderType = mxs.namify( 'bakeSelected' ) )
Thanks for your help :tear:
Finally got an answer from python Blur team :
(fn is the fbx fullname)
mxs.exportFile(fn, mxs.pyhelper.namify( 'noPrompt' ), selectedOnly=True, using='FBXEXP' )
