does anyone know if new macros exist (like SHADOW_FUNCTOR) for accessing soft shadows or SSAO data?
I was interested in this so i had a poke around in max’s memory, so this is part of the contents of “shadowmap.fxh” the syntax may not be entirely correct as it was a quick rough out to see what was going on. There were also some missing and spurious character from the memory dump. There’s also a third macro define called AREA_SHADOW_FUNCTOR…
this is the definition for the SHADOW_FUNCTOR
#ifndef SHADOW_FUNCTOR
#define SHADOW_FUNC_BODY(shadowTerm)
float shadowTerm(float4 wPos)
if (__IsShadowMapValid_##shadowTerm##)
float4 lPos = mul(wPos, __ShadowMatrix_##shadowTerm##);
return ShadowTerm30(lPos,__ShadowMapSize_##shadowTerm##,__DepthSamp_##shadowTerm##, __TransSamp_##shadowTerm##,false, __IsTiledCube_##shadowTerm##,__IndirectCubeSamp_##shadowTerm##,__FaceDataSamp0_##shadowTerm##,__FaceDataSamp1_##shadowTerm##,__FaceDataMapOffset_##shadowTerm##);
else return 1.0f;
#if NVDST_SUPPORTED.
#define __FILTER LINEAR
#else
#define __FILTER POINT
#endif
#define SHADOW_PARAM(shadowTerm)
float4 __PlaceHolder_255_##shadowTerm## : ShadowDataHE
string UIName = "fake";
string Object = "PointLight";
string Space = "World";
int refID = 0;
float4x4 __ShadowMatrix_##shadowTerm##;
float4 __ShadowMapSize_##shadowTerm##;
texture __DepthTex_##shadowTerm##;
texture __TransTex_##shadowTerm##;
textureCUBE __IndirectCubeTex_##shadowTerm##;
texture2D __FaceDataTex0_##shadowTerm##;
texture2D __FaceDataTex1_##shadowTerm##;
bool __IsTrans_##shadowTerm##;
bool __IsTiledCube_##shadowTerm##;
bool __IsShadowMapValid_##shadowTerm##;
float4 __FaceDataMapOffset_##shadowTerm##;
sampler _DepthSamp_##shadowTerm## = sampler_state
Texture = <__DepthTex_##shadowTerm##>;
MinFilter = ##__FILTER##;
MagFilter = ##__FILTER##;
MipFilter = NONE;
ADDRESSU = CLAMP;
ADDRESSV = CLAMP;
sampler __TransSamp_##shadowTerm## = sampler_state
Texture= <__TransTex_##shadowTerm##>;
MinFilter = LINEAR;
MagFilter = LINEAR;
MipFilter = NONE;
ADDRESSU = CLAMP;
ADDRESSV = CLAMP;
samplerCUBE __IndirectCubeSamp_##shadowTerm##= sampler_state{Texture= <__IndirectCubeTex_##shadowTerm##>;
MinFilter = POINT;
MagFilter = POINT;
MipFilter = NONE;};
sampler2D __FaceDataSamp0_##shadowTerm##= sampler_state{Texture =<__FaceDataTex0_##shadowTerm##>;
MinFilter = POINT;
MagFilter = POINT;
MipFilter = NONE;};
sampler2D __FaceDataSamp1_##shadowTerm##= sampler_state{Texture = <__FaceDataTex1_##shadowTerm##>;
MinFilter = POINT;
MagFilter = POINT;
MipFilter = NONE;};
#define SHADOW_FUNCTOR(functor)\
SHADOW_PARAM(functor);\
SHADOW_FUNC_BODY(functor);
#endif
And this is the definition for the SOFT_SHADOW_FUNCTOR, it takes Three arguments but I can’t get it to work, maybe someone else can have more luck.
#ifndef SOFT_SHADOW_FUNCTOR
#define SOFT_SHADOW_FUNC_BODY(shadowTerm, iLightType, bLinearSupport)
float4 lPos = mul(wPos,__ShadowMatrix_##shadowTerm##);
return SoftEdgeShadowTerm(lPos,__InvShadowProjMat_##shadowTerm##,__ShadowMapSize_##shadowTerm##,__LightFrustum_##shadowTerm##,false,__DepthSamp_##shadowTerm##,__TransSamp_##shadowTerm##,__IndirCubeIndexSamp_##shadowTerm##,__FaceMatrixSamp_##shadowTerm##,iLightType,__vEVSMConfig_##shadowTerm##,bLinearSupport);
else return 1.0f;
#define SOFT_SHADOW_PARAM(shadowTerm, iLightType)
float4 __PlaceHolder_##iLightType##_##shadowTerm## : ShadowDS..;
string UIName ="fake";
int refID = 0;
float4x4 __InvShadowProjMat_##shadowTerm##;
float4 __LightFrustum_##shadowTerm##;
texture __IndirCubeIndexTex_##shadowTerm##;
texture __FaceMatrixTex_##shadowTerm##;
float4 __vEVSMConfig_##shadowTerm##;
sampler __DepthSamp_##shadowTerm## = sampler_state
MinFilter= LINEAR;
MagFilter = LINEAR; MipFilter = NONE;
ADDRESSU = CLAMP;
ADDRESSV = CLAMP;
MinFilter = LINEAR;
MagFilter = LINEAR;
MipFilter= NONE;
ADDRESSU= CLAMP;
ADDRESSV= CLAMP;
sampler __IndirCubeIndexSamp_##shadowTerm##= sampler_state
Texture =<__IndirCubeIndexTex_##shadowTerm##>;MinFilter= POINT; MagFilter = POINT; MipFilter = NONE;};
sampler __FaceMatrixSamp_##shadowTerm##= sampler_state
{Texture =<__FaceMatrixTex_##shadowTerm##>;MinFilter = POINT; MagFilter =POINT; MipFilter= NONE;};
#define SOFT_SHADOW_FUNCTOR(functor,iLightType, bLinearSupport)\
SOFT_SHADOW_PARAM(functor, iLightType);\
SOFT_SHADOW_FUNC_BODY(functor, iLightType, bLinearSupport);
#endif
even though I can’t as yet get soft shadows to work in an fx shader the following is quite useful
if you declare the following
SHADOW_FUNCTOR(shadowTerm);
and create the following function
float TshadowTerm(float4 wPos)
if (__IsShadowMapValid_shadowTerm)
float4 lPos = mul(wPos, __ShadowMatrix_shadowTerm);
return ShadowTerm30(lPos,__ShadowMapSize_shadowTerm,__DepthSamp_shadowTerm, __TransSamp_shadowTerm,true, __IsTiledCube_shadowTerm,__IndirectCubeSamp_shadowTerm,__FaceDataSamp0_shadowTerm,__FaceDataSamp1_shadowTerm,__FaceDataMapOffset_shadowTerm);
else return 1.0f;
and use the following call in your pixel shader
float shadow = TshadowTerm(Input.wPosition);
will enable Transparency in the shadows
good idea with the memory investigation and thanks a lot for looking into it.
It works if you activate Soft Shadows in the “Lighting and Shadows” dialog.
SOFT_SHADOW_FUNCTOR(shadowTerm, iLightType, bLinearSupport)
shadowTerm is the return value
iLightType is defined in the dxutil.dll
#define OMNI_LGT 000
#define SPOT_LGT 001
#define DIR_LGT 002
bLinearSupport is a bool (false or true)
a valid call would be:
SOFT_SHADOW_FUNCTOR(shadowTerm, DIR_LGT, true);
the value is fetched by calling:
shadowTerm(worldPosition)
There is still one left: AREA_SHADOW_FUNCTOR
Can’t get this one to work…
